Drag Wall End always selects other wall!
Every time I try to right-click the Drag Wall End control to Disallow Join Revit selects another wall, usually the next wall in the order of joined walls. It does this every time even if I tab to darken the control. I've complained about this in the past as have countless others and still this company refuses to fix it. Every time I have to temporarily isolate the entity first.
Of course non of this would be necessary if they turned the control for allowing a join into a toggle that was always available, as thousands have requested for the better part of ten years, but when has Autodesk ever turned a five step process into a one step process.
