Allow wall to ceiling joins
One of the ongoing frustrations we have is the lack of proper wall to ceiling joins.  This is especially frustrating when modeling say, a soffit where you want materials to connect properly and overlapping geometry deleted as needed. Short of a modeled component, I know of know way of achieving the desired result.
Comentarios
I agree, modeling soffits that look appear correctly in ceiling plans, elevations, sections and 3d is very difficult, and usually requires some compromises.  If you extend a ceiling for the entire base of the soffit you get a line in elevation and vice versa, and neither looks right in sections.  The closest I've gotten to modeling it accurately is to add sweeps to the base of the soffit wall that miter in at the corners.  It works ok, and looks right in sections and 3d, but still usually requires the division between walls and ceilings to be changed to invisible  in the rcp.  Joining sometimes works, but often doesn't.  This method doesn't work well on corners that aren't right angles.
Then there is the issue of window heads and sills.  While walls or families can be set to wrap at inserts it only applies to the jambs, requiring a lot of manual painting for the heads and sills to look ok in 3d
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
