Section cut line visibility toggle
It would be good to have a setting to control the visibility of the section cut line. ie. turn off or on. We can control the cut lines lineweight and colour but not is visibility. Yes we can create the line as white and dot but that still shows over shaded elements.
This visibility toggle would allow you to avoid always breaking the line and adjusting the section cut line grips.
Unless someone has a way?
Comentarios
