Please add the ability to manage links without opening a model. Similar to Reference Manager for AutoCAD.
This will save time for Revit users.
You can find the app External Access Links Manager in the autodesk app store
Yes, Links Manager is a good add-in, unfortunately it marks a central file as moved so you need to open and re-save file as central.
I hope the author of the Links Manager will fix it, if possible. Or Autodesk will make own links manager.
