issue in view range
Can Autodesk improve the view range option? because i need to adjust every time i have different sill height of a windows, for example in toilet window and other room windows, most of the time we cannot see the windows in the floor plans, and it is very confusing if you don't know how to adjust view range or even how to use the plan view. Thanks
Comentarios
thank you sir
