Custom Scale of 1:2.5 required
We have recently encountered the need for the custom scale of 1:2.5 for detailing purposes.
Hopefully this is something that can be addressed and incorporated into the software.
Comentarios
I believe that this relates back to Revit's Imperial Core Units
No Imperial person needs a 1 to one eight and a half scale view.....
I'm 100% with you on this....1:2.5 would be great
The only workaround we have found is to produce the details at 1:5 on an A3 sheet, and then scale the PDF 200% to A1 when printing. View title scales must be manually overridden, and all text/keynotes/lineweights sized appropriately if you want consistency across the entire drawing package.
the great problem is that audtodesk do not listen to the user base. don't hold your breath on this one guys
I have a raft of details that would plot perfectly at 1:7.5 not "enter an integer"
