HSM Support Forum
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
HSM Support Forum
Highlighted
Store as Template Broken - Inventor HSM 2018
140 Views, 11 Replies
04-19-2017 01:30 AM
Hi guys,
A really really annoying issue in Inventor HSM.
Store as template doesn't work when selecting multiple operations.
Can we fix this asap?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Laurens-3DTechDraw wrote:
As an update for everybody @jeff.pek and I have been getting to the bottom of this and it seems we have located the issue.
The guys are looking for a fix.
I'm testing the fix as we speak.Smiley Very Happy
Post 2 of 12
Re: Store as Template Broken - Inventor HSM 2018
04-19-2017 01:57 AM in reply to: Laurens-3DTechDraw
Hi Laurens -
Hmmm... I just tried this several times and don't see any issue.
From the video, it seems like sometimes it just doesn't show the file save dialog?
Any rhyme or reason to this?
Does it seem to be model-specific? Does it always work when there's only one operation selected?
Jeff
04-19-2017 02:04 AM in reply to: jeff.pek
jeff.pek wrote:
Hi Laurens -
Jeff
@jeff.pek
Are you on the current official Inventor 2018 and Inventor HSM 2018 release or some internal build?
It's the same for all 4 PC's in the building and happens on all parts.
As far as I can tell it always works correctly for 1 Operation.
It doesn't show the save dialog, and thus really doesn't save it anywhere.
Inventor HSM Build: 5.1.0.26
Inventor Build: 112 Release: 2018
Laurens Wijnschenk
3DTechDraw
René for Legend.
Post 4 of 12
04-19-2017 02:12 AM in reply to: Laurens-3DTechDraw
Hi Laurens -
Yes, I've tried with the official build.
I saw your video show the save dialog -- it went by kind of quick -- was that with just a single op selected? Or does it work sometimes?
I'll have to take a closer look and see if there are situations that would prevent it from showing the dialog.
Jeff
04-19-2017 02:18 AM in reply to: jeff.pek
@jeff.pek
It works for one operation. That's when you see the Dialog.
But when selecting multiple operations it always fails me.
Doesn't matter if it's a new model like in the video or a imported or a 2017 model.
If I select one operation and click the store template, the GDI Objects rise for the Inventor.exe,
but when I select multiple operations I see no change there.
I can't test with Inventor 2017 with HSM 2018 because they broke that license.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Post 6 of 12
04-19-2017 02:21 AM in reply to: Laurens-3DTechDraw
Hmmm.
The GDI objects rise, and don't go back down?
What do you mean "they broke that license"? Is this related to network licensing?
Jeff
04-19-2017 02:26 AM in reply to: jeff.pek
jeff.pek wrote:
Hmmm.
Jeff
Yeah, The network license issue.
I've given up getting it to work like it should. No way you can actually explain someone what there should be left and what should be included in each license and how many years back. So 2018 runs, and I pray that the releases are solid.
The GDI objects rise and go back down for 1 Operation after you close the window.
Multiple operations does nothing.
Laurens Wijnschenk
3DTechDraw
René for Legend.
04-19-2017 02:51 AM in reply to: Laurens-3DTechDraw
Hi Laurens,
I don't see the problem on my pc. A while back in the time of perpetuals you could not mix a standalone Inventor with Network HSM or the other way around. Maybe thats still the case.
On my pc with an old school perpetual license both Inv2017 an 2018 work with HSM2018.
CAM Trainer and Postprocessor developer in Netherlands and Belgium for Inventor HSM, HSMWorks and Fusion 360
04-19-2017 03:10 AM in reply to: Arjancncmachineworks
Arjancncmachineworks wrote:
Hi Laurens,
(My License issue is in the Account not in the technical use. My PC is running fully network licensed, and I've other PC's fully on subscription)
But do you not see the store template issue when selecting multiple Operations?
Laurens Wijnschenk
3DTechDraw
René for Legend.
04-19-2017 07:57 AM in reply to: Laurens-3DTechDraw
Laurens Wijnschenk
3DTechDraw
René for Legend.
04-19-2017 10:01 PM in reply to: Laurens-3DTechDraw
Laurens Wijnschenk
3DTechDraw
René for Legend.
Post 12 of 12
Betreff: Store as Template Broken - Inventor HSM 2018
04-21-2017 01:52 AM in reply to: Laurens-3DTechDraw
i've the same issue like Laurens and one more with templates ( This has already occurred with Inventor 2017 )
When i change the folder where the templates are stored then inventor crashes ( please look at the attached video ).
Mario
InfoInventor HSM(Ultimate) user
Habe ich meine Beiträge auf Richtigkeit geprüft und getestet? Nicht unbedingt, alles ohne Gewähr!
Vorkommen von Schreibfehlern? Ständig, meist sind die Finger schneller als das Auge oder ich weiß es halt nicht besser.
Jemand anderen beleidigen oder niedermachen? NIEMALS ABSICHTLICH! Leben und leben lassen. Seltsame Art von Humor mir angeboren ist.
