Rotary 4th-axis toolpath in inventor CAM
ross.calvertW5SAF
Observer Observer
ross.calvertW5SAF
Observer
Observer
Is it possible to create a rotary 4th-axis toolpath when milling in inventor CAM similar to in machining extension of fusion 360 detailed here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-create-a-4-...
Thanks for any help as I've been trying for a while with no success!
kacper.suchomski
Hi
Yes, but only for pockets; not for profile.
Kacper Suchomski
ross.calvertW5SAF
Observer
Observer
I'm aware I can wrap 2d toolpaths etc, but it's not possible to do the rotary-style profile cut like the above in fusion 360.
timsautodesk2015
Is your post configuration set up for 4th axis (rotary axis)?
timsautodesk2015
you also have to orientate your tool to the correct plane, or feature
