HSM Support Forum
Problem with Chamfer
8 REPLIES 8
Message 1 of 9
493 Views, 8 Replies
Can someone help me figure out what is going on with this? In this assembly file whenever I try to do this 2d chamfer it exits and enters around the chamfer. I cannot get it to stay in the part and complete the chamfer in one step. It works fine in the same settings in a part file. I am lost.
8 REPLIES 8
Message 2 of 9
LibertyMachine
This is most likely being caused by the Tolerance setting on the "Passes" tab. Open it up to a larger value, should cure the problem.
IF it doesn't, could you share your file?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 9
Steinwerks
in reply to: LibertyMachine
There is no Tolerance field in HSMWorks still @LibertyMachine, you have to go into Compare & Edit to change it @Anonymous
I find a tolerance of .0015" usually takes care of it.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 9
LibertyMachine
in reply to: Steinwerks
I didn't see the HSMworks callout, I assume that was gleaned from the screenshot?
And HSMWorks doesn't have that? Sheesh......
Seth Madore
Message 5 of 9
The file is huge since its an assembly with a bunch of parts.
Here are the settings. I have changed just about everyone and it has no effect.
Message 6 of 9
Yes!!! This did it! Thanks!
Message 7 of 9
Steinwerks
@jeff.pek
I believe this bug is now over a year old roughly seven months old, any news? I will see if I can dig up the original thread.
Edit: found the email, should be CAM-5068 I believe.
Edit 2: also this: https://forums.autodesk.com/t5/hsm-support-forum/2d-chamfer-oddity/m-p/6370941#M14830
CAM-4370 from June last year.
Neal Stein
Find me on:
Message 8 of 9
jeff.pek
@Steinwerks: You're right that these are still open. Adding @fonsecr to chime in.
Message 9 of 9
fonsecr
in reply to: jeff.pek
2D Chamfer do have limitations on for which geometry is can be used for. But I do hope to get around to getting some of these problem fixed soon.
René Fonseca
Software Architect
