I just built a new CNC so I'm switching from a Shopbot post processing file to a mach3 post processing file for the first time.
I'm just trying to do a test cut, so i have a small part with a hole in it. (I attached the sldprt file) I switched the Post Configuration to: mach3mill.cps - Generic Mach3Mill and left everything else default. When I run it, I get a long list of errors that I never saw using the shopbot post processing. I started looking through the code, but haven't figured much out yet. Anyone know how to solve this? Here is the error log output it's giving me:
Information: Configuration: Generic Mach3Mill
Information: Vendor: Artsoft
Information: Posting intermediate data to 'C:\Users\Steve Nelson\AppData\Local\HSMWorks\nc\2D Contour1.tap'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Loading locale from 'C:\Program Files\HSMWorks\locales\english_us.xml'
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, November 15, 2016 2:43:29 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41078
Configuration path: C:\Program Files\HSMWorks\posts\mach3mill.cps
Include paths: C:\Program Files\HSMWorks\posts
Configuration modification date: Monday, August 15, 2016 12:01:06 PM
Output path: C:\Users\Steve Nelson\AppData\Local\HSMWorks\nc\2D Contour1.tap
Checksum of intermediate NC data: c44d69f2b28d8049d8b13f0305e89431
Checksum of configuration: 12b039c11340a330fd47f654e13305a6
Vendor url: http://www.machsupport.com
Legal: Copyright (C) 2012-2016 by Autodesk, Inc.
Generated by: HSMWorks 2016 R4.41148
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Invalid coolant mode
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, November 15, 2016 2:43:29 PM
Post processing failed.
