post process all setups in one comand?
Coras_Alin
Coras_Alin
is there a way to postprocess all setups each one with its own program in one command or a keyboard shortcut? , it would simplyfy a lot postprocessing 8 setups per part.
JonathanGA5U3J
I would have to say no because there would be no way to have multiple programs with the same name and no way to have them named different.
What you can do is post them as one program, with a hard stop before the new job and have a comment on the next setup.
Coras_Alin
i mean, to name them 1001, 1002, 1003, etc...   Post all setups at once and get each    .nc separatly like if you doing each one by one, for me it doesn't seem imposible, it should be an easy task.  If for exemple 2 of the .nc have the same number 1001, 1001, let's say forget to change them, then you should get a warning, and if accept just receive 4 programs instead of 5. The second thing will help if duplicate 1001, the next one should automaticly get  1002, not to change it manualy, nobody wants 2 of 1001 in same part.   The porpose of this is to get lose of 50 clicks just for 6 operations.
lenny_1962
this was asked for way back in 2018, check the answer from an AD employee
https://forums.autodesk.com/t5/hsm-post-processor-forum/post-process-multiple-setup-folders-at-once-...
