Part Positioning
Part Positioning
rgollob
Message 1 of 1
Part Positioning
rgollob
Need some help. I am having issues figuring out to how change the position of a part in the manufacturing file from 1 operation to another. Normally its easy for me to accomplish as I usually can just bring another fixture and constrain in the proper orientation as its more for visual purposes than anything. (i.e. clamp a part on op1 flip 180deg clamp for op2).
In this specific situation I need to flip the parts 180 degrees on a 3 sided tombstone from OP1 to OP2. since the parts are all positioned at different angles Im having a hard time figuring out how to make this work maintaining the same parts in the op2 setup. any recommendation? My current plan is to make a second assy with all different parts in the proper configuration and try to make a stock that matches OP1 so I can track what has been machined from OP1 to OP2.
Replies (0)
