Parallel toolpath X location differs from right to left
Message 1 of 1
Does anyone know what's going on here with this Parallel Toolpath?
On left side the point where it transitions down is about in the same X but on the right side it is all over the place.  Messing with the tolerance changes things but doesn't help a whole lot.  Nor does changing it from both ways to one way or the other.  See attached picture comparing them and I attached the Fusion file.
Using Fusion 360 but also did a similar test with Inventor HSM and got the same results.
I wouldn't normally care too much but I am having a gouging issue on the part that I think is somewhat related.
Replies (0)
