Message 1 of 10
Nesting of finished programs
We have a vacuum table and mill there various parts.
I took a look at the nesting utilities but they don't help me here.
You can only nest and then program the parts.
This is good for laser cutting, but not for milling.
1. the nesting of milled parts is different from laser cutting.
You have parts with entrances and exits because they are open pockets. Therefore the distance between the parts is not always the same everywhere. The distance per part must be calculated on the cutting path.
2. sometime you have programmed the part and it is ordered again. Now I have to nest several ready-made programs. You don't want to redo 30 operations.
For the whole vacuum machining we currently use a different CAM because we have no solution for this in Inventor HSM.
Is that possible in Inventor HSM? Is there a quick way to nest finished programs? Possibly also manually.
I tried but didn't find a good way.
