Hallo
I created a simple model with a simple cutout. Now I am placing a 2D Adatpive milling for the cutout. The model is 400 mm long. Now I change the length to 300 mm. However the 2D Adaptive milling does not go with it. If I reactivate the 2D Adaptive milling it goes to its new position. Is there a possibility that if you change the model the milling automatically updates with it? Imagine if you have multiple tooling in your model that you have to reopen them all one by one after a change in your model.
We work with parametric models to which all cam tooling is added and which we copy from the Vault with copy design. That new model is adjusted in length and depth. Assuming that the tooling goes automatically with the model adjustment.
