Manually open Cimco Editor (Autodesk HSM Edit)
How do I open the Cimco Editor (Autodesk HSM Edit) outside of Inventor CAM 2020? I want to manually write my g-code files then
1) open the *.nc file in Inventor CAM 2020
2) run Backplot (I'm unable to select Haas lathe)
I try running Cimco using this path
C:\Program Files\Autodesk\Inventor CAM 2020\editor\AutodeskHSMEdit.exe
but when I attempt to edit the file, get this Out of memory error, so I think I'm doing something wrong.
thanks,
Juan
jeff.pek
Does that happen if you just load the editor, without loading a .nc file?
Can you tell me which build of Inventor CAM you have installed?
  Jeff
