Machining Boundary
Machining Boundary
Machining Boundary
HI guys,
im doing a ramp tool path on the out side of this fly wheel cover and i do not want it to do the k in the center. ive been messing with the machining boundary but i cant find the option where i can tell it to stay out of a certain area. thanks jeremyproblem with k.PNG
Marco.Takx
Hi @Anonymous,
If you use the 3D  Milling -> Ramp operation what you can do at first is to create a Patch surface for the contour of that logo.
After created that you can use the Model setting within the Geometry tab and add the patch surface to this operation.
2018-06-25_08-59-09.pngIf my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
I've been looking for a solution to this problem for a long time.  Maybe i'm overthinking it, which is entirely possible.
Seems autodesk assumes that everybody only machines on the inside of a boundary.
It'd be nice if you could set multiple "inside" boundary lines and multiple "outside" boundary lines.
lenny_1962
like any cam software sometime you either need to cover up or draw a sketch to help avoid or control were a tool goes.
you could draw a doughnut  sketch to contain toolpath usually works pretty good.
I use power mill 40 plus hours a week as a full time programmer at my day job.i run my own shop at night and got hsm because cad/cam is way nicer then separate programs also i could have both for just shy of half the price of power-mill. swapping between the two software is a constant struggle, but both have there pros and cons but if i could as the hsm team to look in to a few things it would be boundary and the wcs of power mill is light years ahead. just if you could click the area like a profile to say what side of the boundary you wanted i would have saved hours over the last couple weeks. thanks to every one who chimed in and help i did get it... eventually!
