Adam I see that you have activated your license already so I am assuming you have received your license.
Same issue, registered for download but have not received my license. Thanks.
Just to update my situation, I was using Firefox and did not see the disclaimer stating there are issues with it. I had no issues when using Internet Explorer.
I don’t see your name or email listed in our system please try registering again using Windows Internet Explorer.
I have also not received an email that contains a license key. I have attempted to submit my information several times using both Chrome and IE browsers. I have have unsuccessfully checked my spam / junk mail folders...
Todd
Hi @highflyer123,
Welcome to the community!
Sorry to hear about the issue. Can you double check that there are no typos when you register for the HSMXpress license? If you continue to have issues then send a screen dump of the registration form before you submit it to cam.support@autodesk.com so we can have a look. The registration form should work fine with all browsers but just in case you can try with a different one.
For HSMXpress:
http://cam.autodesk.com/get-hsmxpress/
For Inventor HSM Express:
http://cam.autodesk.com/get-inventor-hsm-express/
Anyone else experiencing this problem, please contact us via the cam support email.
@highflyer123 wrote:
hi mathew It was filled correctly as I have received other emails from autodesk (which i previously stated) So you reeeeaaaalllly arent going to send out a serial eh? thanks a lot for treating me like an idiot
I'm pretty sure they checked the database for your e-mail and if it's not in there not really weird to ask you to do it again right?
Is it the same e-mail as you are using here that you used to register for HSMXpress?
Have you filled it in again and send the screenshot to the e-mail as requeted above? In that case the guys will probably contact you shortly.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Not the intent at all @highflyer123. I do apologize for the issue with this, we are having a bit of trouble locating your email. Could you please contact the CAM directly at hsmexpress@autodesk.com and the team will send you a license number manually.
