Inventor HSM 2016 Post Processor documentation
ubunibme
Message 1 of 9
ubunibme
I'm in the process of writing a PP for the Tormach SlantPRO, which is a simple XZ, single spindle lathe.
A couple of questions:
1) Is there any documentation for some of the background objects, such as 'machineConfiguration', or the 'operations' collection, or tool properties?
2) Is there a source level debugging environment available?
Replies (8)
Message 2 of 9
Laurens-3DTechDraw
I wrote up some info on editing a post processor here: https://camforum.autodesk.com/index.php?topic=6138.msg24305#msg24305
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 9
ubunibme
I read that documentation, it's more of a tutorial on the event structure and doesn't give any detail of the inner objects. What I've done in other PPs is write a header in the output gcode, that lists tools and ops under that tool, plus the amount of time the op takes and the minimum Z level that is reached. I'm in a situation where I do a lot CAD/CAM and setups for short run, and find this header to be a good reality check. I'll try to enumerate the properties and see what's there.
Message 4 of 9
Laurens-3DTechDraw
In the help file that is included with that post you can find all the actions you can call. I'm not sure what else you might need. Also have a look at the setup sheet post processors since they already output everything you want.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 5 of 9
ArjanDijk
Also have a look at the setup sheet postprocessor. You see a good example where all this data is outputted.
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
Message 6 of 9
Laurens-3DTechDraw
That's what I said above.  8)
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 7 of 9
ubunibme
Laurens, thanks for the tip .. looks good. Your help file however, comes up in a help browser just fine, but none of info is displayable in the pane to the right. Can you post a new one? Or is that file available with the HSM Inventor download?
Also: The Tormach lathe uses a convention for G96 as thus: G96 S70 D1000 M3, where 'S' is the CSS value and 'D' is the max RPM. What is the property for the setting: 'op'/Tool/Feed & Speed/Maximum Spindle Speed?
Message 8 of 9
ubunibme
Ignore that last question .. got it!
Message 9 of 9
ubunibme
Got it. I though I'd share some code to do the listing I was talking about above. Not the best code in the world ( new to JS ), but gets the job done.
This is called from on open and lists the tool sequence with the underlying ops per tool with the minimum Z and cycle times.
// formats the tool line in the header to display min Z and CycleTime
function entryFixup( entry, minZ, ct ) {
    ct += 0.5;
    var d = new Date(1899, 11, 31, 0, 0, ct, 0);
    var zCol = 42;
    var ctCol = 60;
    if ( entry.length < zCol ) {
        for( var i = entry.length; i < zCol; ++i ) {
            entry += " ";
    entry += "Z : " +  zFormat.format( minZ )
    if ( entry.length < ctCol ) {
        for( var i = entry.length; i < ctCol; ++i ) {
            entry += " ";
    entry +=  "CT: " +
                timeFormat.format( d.getHours( ) ) + ":" +
                timeFormat.format( d.getMinutes( ) ) + ":" +
                timeFormat.format( d.getSeconds( ) );
    return entry;
/** writes the tool and op info. */
function writeToolInfo() {
    var result = [];
    var lastToolIndex;
    var _maxZ = 1000000;
    var minimumZ;
    var cycleTime;
    var tn_;
    var numberOfSections = getNumberOfSections();
    for (var i = 0; i < numberOfSections; ++i) {
        var section = getSection(i);
        // the next tool is up...
        if (section.getTool().number != tn_) {
            // fix up the last tool entry...on the first iteration tn_ will be empty
            if (tn_) {
                result[ lastToolIndex ] = entryFixup( result[ lastToolIndex ], minimumZ, cycleTime );
            cycleTime = 0;
            minimumZ = _maxZ;
            tn_ = section.getTool().number;
            lastToolIndex = result.length;
            result.push( new String( "-- tool: " + tn_ + " " + section.getTool().vendor + " " + section.getTool().description ) );
        if ( is3D( ) ) {
            minimumZ = Math.min(minimumZ, section.getGlobalZRange().getMinimum());
        cycleTime += section.getCycleTime();
//      if (properties.rapidFeed > 0) {
//          cycleTime += rapidDistance/properties.rapidFeed * 60;
        result.push( new String( "          op: " +  section.getParameter( "operation-comment" ) ) );
    if ( result.length > 0 ) {
    writeComment("Tool / Op list ...................................................")
    for (var i = 0; i < result.length; ++i )
        writeComment( result );
output looks something like this...
; Tool / Op list ...................................................
; -- tool: 2  SVJBR12-3B                    Z : -0.02        CT: 00:00:25
;          op: face part
; -- tool: 20  #3 Center drill              Z : -0.1258      CT: 00:00:03
;          op: center drill
; -- tool: 2  SVJBR12-3B                    Z : -1.9743      CT: 00:06:12
;          op: diameter roughing
;          op: rear roughing
;          op: finish profile
; -- tool: 15 Dorian Slot Grip              Z : -1.858        CT: 00:00:10
;          op: part-off
I find this useful .. maybe someone else will
