Inventor CAM API functionality
I looked at the Inventor CAM API documentation:
C:\Program Files\Autodesk\Inventor CAM 2021\Help\InventorHSMAddinAPI.chm
But the API looks very limited. Several methods don't even have any properties or methods defined.
Is this all the functionality there is, or is there more too it somehow?
I'm specificially looking for functionality such as:
- Save REmaining STock (simulation result) to stl.
- Load stock from stl.
- Set clamping models
Is there any functionality which allows this to be done through API?
boopathi.sivakumar
Currently
are not exposed via API so you don't have access to those. At the moment there are certain limitations to the CAM api. you don't have access to all the options
Boopathi Sivakumar
Senior Technology Consultant
