HSMWORKS setup sheet not working after installing HSMWorks 2017
Message 1 of 9
After installing HSMWorks 2017 I can not get the setup sheet post to work. I am getting the following error message. I noticed that in line 6 it's loading locale is HSMXpress. Should I uninstall HSMXpress?
Information: Configuration: Setup Sheet
Information: Vendor: Autodesk
Information: Posting intermediate data to 'C:\Users\jasons\Documents\HT301-01_S8D3.html'
Error: Failed to post process. See below for details.
Loading locale from 'C:\Program Files\HSMXpress\locales\english_us.xml'
Code page changed to '1252  (ANSI - Latin I)'
Start time: Monday, January 16, 2017 12:17:18 PM
Code page changed to '65001 (UTF-8)'
Post processor engine: 4.2.1 41279
Configuration path: C:\Users\jasons\Documents\HSM POST\setup-sheet.cps
Include paths: C:\Users\jasons\Documents\HSM POST
Configuration modification date: Tuesday, December 6, 2016 12:01:50 PM
Output path: C:\Users\jasons\Documents\HT301-01_S8D3.html
Checksum of intermediate NC data: d6c26c720b810fb2a2b8735bdf91b9f3
Checksum of configuration: ae6994f02599ff892f2588354956a32e
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2016 by Autodesk, Inc.
Generated by: HSMWorks 2017 R1.41464
Error: Error: Failed to read document 'C:\Users\jasons\Documents\HSM POST\setup-sheet.css'.
Stack dump:
("Failed to read document 'C:\\Users\\jasons\\Documents\\HSM POST\\setup-sheet.css'.")@:0
onOpen()@C:\Users\jasons\Documents\HSM POST\setup-sheet.cps:214
Failed while processing onOpen().
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to invoke function 'onOpen'.
Error: Failed to execute configuration.
Stop time: Monday, January 16, 2017 12:17:18 PM
Post processing failed.
Replies (8)
Message 2 of 9
fonsecr
Hi @Anonymous,
You have copied the setup sheet (setup-sheet.cps) into your own personal folder (C:\Users\jasons\Documents\HSM POST). So you have to make sure you also copy any dependent files (in this case setup-sheet.css).
René Fonseca
Software Architect
Message 3 of 9
fonsecr
About HSMXpress.
It sure looks like you are running HSMXpress rather than HSMWorks. The last installed product will be the active one in SolidWorks.
If you no longer use HSMXpress, then you can uninstall it. And then reinstall HSMWorks again to make sure it is registered as an add-in in SolidWorks.
René Fonseca
Software Architect
Message 4 of 9
Thanks for the reply. I got the same error message after moving the .css file. I also got the same error when I used the post from it's original location. I will try to uninstall Xpress.
Message 5 of 9
I uninstalled Xpress and HSMWorks 2017, reinstalled HSMWorks 2017. I still get a very similar error message. Xpress reference is gone.
Information: Posting intermediate data to 'C:\Users\jasons\Documents\HT300-01_S15D2.html'
Loading locale from 'C:\Program Files\HSMWorks\locales\english_us.xml'
Start time: Monday, January 16, 2017 1:28:23 PM
Configuration path: C:\Program Files\HSMWorks\posts\setup-sheet.cps
Include paths: C:\Program Files\HSMWorks\posts
Output path: C:\Users\jasons\Documents\HT300-01_S15D2.html
Checksum of intermediate NC data: c96cca6d0ed07550a58edf1477b99b88
Error: Error: Cannot format NaN.
Stack dump:
("Cannot format NaN.")@:0
writeTotals()@C:\Program Files\HSMWorks\posts\setup-sheet.cps:1029
onSectionEnd()@C:\Program Files\HSMWorks\posts\setup-sheet.cps:598
Failed while processing onSectionEnd() for record 403.
Error: Failed to invoke function 'onSectionEnd'.
Error: Failed to invoke 'onSectionEnd' in the post configuration.
Stop time: Monday, January 16, 2017 1:28:23 PM
Message 6 of 9
fonsecr
That is a different issue. I had a bug in a recent HSMWorks release that caused this.
Please just download the setup sheet from here at that should go away:
http://cam.autodesk.com/posts/?p=setup-sheet
René Fonseca
Software Architect
Message 7 of 9
THANKS problem solved.
Message 8 of 9
Hi fonsecr,
Once the set up sheet folder is downloaded how do you use it with HSM?
JWatson
Message 9 of 9
jeff.pek
Hi -
You should be able to use the Post Process command, and then navigate to the folder where you put the downloaded post to create a setup sheet using it.
Or, (I think this will work) you can right-click in the operation manager, and choose Options->Select Default Setup Sheet. This will prompt you to locate the post that you want to use when creating setup sheets using the Setup Sheet command.
Jeff
