HSM works not recognizing threads on multiple models *No threads selected error*
I have been having problems I know there is a simple solution for, it's just not known by me. I have several models in Solidworks 2015 that HSM will not recognize threads. When I select the thread segments (edges and faces) there is a persistent no threads selected error. Has anyone run into this? If so, what was a a solution. It should be noted I am not an extraordinarily good Solidworks user. I have verified the correct geometry on the threads in the model, and tried a couple different revisions of the models to make sure it wasn't an isolated problem.
Laurens-3DTechDraw
Do you want to machine the outer thread that has been modeled?
That the software won't understand. It will only understand a "normal" circular face.
Now your problem probably arises since you need it starting point at a certain angle or not?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Thanks so much for your reply. No leads or start angles are required. So if I am going to try to suppress the feature and try it as a plain circular face, with of course feeds and parameters typical to threading within HSM. AAAAnnnnnddd.. OH snap, it worked..Thanks!! ;D
