HSM Edit - Problem with backplot
Hi.
I have a small problem with bakplot. If Control Type = ISO Milling the trajectory is displayed correctly (see pic.1). But if Control Type = Haas/Fanuc Milling then all the arcs are converted into straight lines (see pic.2).
In CIMCO Edit bakplot always correct, but I'd like to use HSM Edit for my work.
Another example. The Inventor HSM arc are displayed as straight lines. In Cimco Edit all displayed correctly. I attached the program file to the message so that you can check.
scottmoyse
Which control are you trying to simulate?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Haas control.
It seems that the HSM Edit backplot does not work correctly if you select another type of control (Haas/Fanuc Milling).
