How to modified "default" parameters for CAM configuration
fraxyJQKHU
fraxyJQKHU
Sorry my poor english please..
I'm asking today some help cause sometimes i forget to modify some parameter, and it stuck on my machine after..
So, can i modify the "default" parameter of fonction ? exemple, the conventional way to mill instead of "en avalant"..
Or the point of origine on stock into the CAM configuration.
Thank you so much for your help !
Wingdinger
Hi, I assume you're referring to HSMWorks? It does allow you to set many parameter values as default, although not all. In the operation tabs, simply set a parameter as desired then right-click in the box to get the option to set it as default. Unfortunately HSMWorks is not as good at it as Fusion, which allows you to set almost any setting as default, HSMWorks does not have that luxury.
fraxyJQKHU
Hello, i dont know about Fusion, but i'll try your way to do soon !
Thank you
fraxyJQKHU
It Works, but not for all parameters. Can i access to a "config files" you think ?
Wingdinger
I don't think there is a configuration file, as far as I know there is simply no option to set all parameter defaults. I really wish there was.
Wingdinger
I've since discovered how to set many more parameters as default, although I haven't tested everything. You need to do it in Compare and Edit mode. Right clicking on a parameter will then allow you to set it as default. It's a little convoluted, but at least it's there.
