Help to do this operation
CCarreiras
Mentor Mentor
CCarreiras
Hi!
I would like to remove that eccentric volume.
Using a turning machine, with milling capabilities in y axis
Trying to do the finish operation, but is not finishing all the part.
What i'm doing wrong?
Is this the better approach to do this part?
CCarreiras
kacper.suchomski
Hi Carlos
Adaptive and pocketing strategies are used for roughing. Their advantage is that they automatically find the space for material removal based on a comparison of the model with the stock, and one of their features is built-in tolerance for rests and inaccuracies.
I think that a simple Contour 2D strategy with the wrapping option indicated will be enough for this task.
I also removed the stock material because defining a virtual resource makes it easier to select edges and surfaces when creating toolpaths.
I also changed the cutter to a straight cylinder, because such a tool will not leave rounded edges after machining.
Does this machining program meet your requirements? Did you have other goals for this project?
Kacper Suchomski
CCarreiras
Hi!
I like your approach!
Thank you!
CCarreiras
CCarreiras
Unfortunately, this process will not work using a 12mm tool...
Any idea?
CCarreiras
kacper.suchomski
Sure, you can add more passes.
In the next steps, I also showed how to extend the path and how to remove unnecessary auxiliary movements in this case.
Kacper Suchomski
