HSM Support Forum
Fusion, 2d pocket Entry Position
24 REPLIES 24
Message 1 of 25
HughesTooling
2522 Views, 24 Replies
Is there any way to make a 2d pocket start where I want it.  I want to start as close to the centre of the pocket as possible but it wants to start at the end point below. The point where it wants to start is the worst place it could be! If I set a pre drill position it will start where I want but then I can't have a helical plunge.  Simple test file attached.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
24 REPLIES 24
Message 21 of 25
DS_P
in reply to: HughesTooling
How is this not fixed yet? I'm having problems with it ignoring predrill completely despite a point being correctly selected inside the part.
Message 22 of 25
lenny_1962
in reply to: DS_P
At this point it ain’t going to happen, been 4 years and squat.
Message 23 of 25
blurango
Was hoping to have a solution for this 5 years later. Currently want to throw my computer out the window programming the most simple part because of this.
Message 24 of 25
Marco.Takx
in reply to: blurango
Hi @blurango ,
I agree that it is a shame it still can't do this.
A workaround could be to do a Drill operation on that specific point and choose a Bore Cycle.
Then you can use the Predrill position within the 2D Pocket to plunge into that created hole and start the pocket milling.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 25 of 25
lenny_1962
Isn't going to change so you'll either live with it or buy other CAM, HSMWorks is frozen at this point no new stuff only Fusion gets new stuff.
2D Adaptive starts in the center.
you can create a circle surface the bore the inside then use 2D Pocket with drill location as a work around, see pics.
bore and 2D pocket at drill location.JPGbore and 2D pocket at drill location -WITH TOOLPATH.JPG
