Hello all,
I am attempting to engrave on a cylinder by using a wrap tool path. It will generate the tool path but whenever I post (Fanuc) it tells me that my machining configuration does not support movement. I've discerned that it is looking for a 5 axis post processor which I don't have since I just have a 3 axis machine with a rotary table. My question is, is there another way to go about this with just a 3 axis mill and rotary table? I have tried trace and multi-axis contour but I can not get it to act the way I want. I have attached the file so maybe someone can take a look.
I have also always used the CamWorks font style which I am learning does not seem to work well with wrapping tool paths as it has open contours. Can anyone recommend a better font for this sort of thing? What sort of tool performs best?
If you haven't noticed, I am still a beginner.
Thanks for your help!
Edit: I forgot to mention that I use Solidworks with HSMworks.
