Edit CAM Marking Menu
TomBarosso3248
TomBarosso3248
I'd like to edit the marking menu that's active when in the CAM environment. I thought his would be a Sub-Environment of the Part Environment but don't see anything.
Can someone steer me to the correct location.
Tom
kacper.suchomski
Hi
Do you mean the RMB radial menu?
Kacper Suchomski
TomBarosso3248
Yep, that's the one.
kacper.suchomski
Unfortunately, the CAM environment is not formally an environment in the sense of the Inventor interface.
As far as I know, this cannot be changed.
I once suggested that this should be turned into an environment - it would make defining shortcuts and managing the browser easier, and would remove the frustration when opening files.
https://forums.autodesk.com/t5/inventor-ideas/inventor-cam-as-an-environment/idi-p/12433511
Unfortunately, it did not gain support, and the Inventor CAM module itself seems to be a dead project with no development and no future prospects. 😔
Kacper Suchomski
TomBarosso3248
Thanks Kacper. That's unfortunate, but not at all surprising.
Tom
