Cutting a deep V groove in HSM express
Hi there,
First time user trying to do what I can only imagine is extremely simple, yet I can't get it to work - cutting a deep V groove in a piece of stock.
I have a 90deg v cutter with a width of 12.6mm and want to cut a groove trough the middle, almost through the stock which is 40mm thick.
Apparently there is no such thing as a v groove bit in HSM, so I am using a chamfer tool with a tip diameter of 0mm. Is this the appropriate way to do it?
I've tried all the different 2D tool-path strategies, but either they can't generate a tool-path, or the tool plunges to the bottom and either moves in a square the size of the top contour or just along the bottom edge (which would obviously break the tool and doesn't cut the sides of the grooves).
I have attached a part file showing what I want to accomplish, can anyone describe (like they are talking to a 10 year old) how to achieve this?
Thanks!
