Circular Interpolation G02 / G03 wrong output BUG
parobillard
parobillard
Hi
I programmed a part yesterday and the outside radius of the part was 0.030" (0.75mm) offset at the top. Why did this happen?
The simulation show the tool is offset.
I've attached the parts in inventor 2016 format with the wrong toolpath.
To make the part the right way I had to draw 2 arc then click the scetch to have the right output.
What's the problem???
 thank you
jeff.walters
could you atach the machine code as well? what post are you using?
Jeff Walters
Senior Support Engineer, CAM
parobillard
Hi Jeff
Here's the code
The post I'm using is from the genereic fanuc with ALOT of modifications to fit my needs (my cnc's are CTEK brand (taiwan)).
But the post shouldn't be the problem as the error is also present in HSM express 2016 simulation.
I've check the coords in the output code and the center of the arc is 0.001" offset in X axis and 0.031" offset on the Y axis. I checked the radius and it's the good one.
The first line with the error is at line 27 (N125) in the code.
thank you
jeff.walters
I have reported this to development on ticket CAM-4369. I'm not sure if it is the same issue that was fixed in HSMWorks, I just know it’s still a problem in the latest development release of Inventor HSM.
Jeff Walters
fonsecr
FYI We are currently looking into this issue.
René
René Fonseca
Software Architect
popaa
I have fixed the issue. It will come out in a future release.
Aurelia
Aurelia Popa Nielsen
SW Development Engineer
