Hi All ,
My customer has two different machines. They use HSMWorks R2.41474 and SOLIDWORKS 2017 SP2. They did desing the machines. But , They can not worked correctly when set up the machine simulation.
We did try machine simulation like in the below link. But it did not work right.
https://www.youtube.com/watch?v=dJuArpNenJ4
I send you machine cad model. Could you tell us where we made the error? I write the machine axis values below. Also I have a lot of machines working. I get an error when defining a new machine.
MAKINO V33 (5 axis index machine)
X axis : -600 / +0 (Head Move)
Y axis: -400 / +0 (Table Move)
Z axis: -350 / +0 (Head Move)
C axis: -360/ +360 (Table Move and 4. axis)
B axis: +17 / +117 (Table Move and 5. axis)
MAKINO V77 (3 axis Machine)
X axis : -1200 / +0 (Head Move)
Y axis: -700 / +0 (Table Move)
Z axis: -650 / +0 (Head Move)
Could you help me please ?
Best Regards ,
MEHMET CAN YILDIRIM
Sorry for the delayed response, Mehmet Can. If others aren't available to answer this, Rene can hopefully respond when he's back from holiday next week.
jeff
Hi jeff ,
Thank you for your interest. I look forward to hearing from you.
Best Regards ,
MEHMET CAN YILDIRIM
Hi Mehmet,
The 3-axis machine has been setup but I cant tell if you have the axes moving in the desired direction. I can only really only see if it has been configured. Your table does have too many components (+100) selected which SolidWorks doesn't like in the selection boxes. Slows down the UI quite a bit.
For the 5-axis machine can you share your configure assembly instead? The one you shared is the raw CAD model only as far as I can tell. Will make it easier to see what you want.
