3d pocket flat area detection bug
user87246
user87246
When using 3d pocket and you select flat area detection it overrides your max stepdown and makes it uneven. The only way to fix it is use shallow areas and unselect flat area detection.
lenny_1962
Fusion? IVCAM? SW\HSMWorks?
user87246
Inventor Cam
lenny_1962
hate to say probably wont get fixed as IVCAM\HSMWorks are in maintenance only mode now.
user87246
Which leaves us no choice but to switch to another cam software for ITAR reasons until fusion 360 makes and offline version.
kacper.suchomski
Hi
  1. To investigate the topic, you need a file. Screen does not provide a way to verify / solve the problem. You can create a similar analogy if the original file is covered by an NDA.
  2. You may consider FeatureCAM in the future.
Kacper Suchomski
