Prusa MK3 & MK3s dimensions incorrect in post processing
No real issue, but the build volume dimensions for two of the Prusa 3D additive printers are incorrect.
The MK3 and MK3s have a build volume of 250mm x 210mm x 210mm, currently in Fusion 360 machine configuration the dimensions are listed as 250mm x 210mm x 200mm.  The MK2 and MK2s build volume dimensions are correct; the MK2 is listed in my screenshot from Prusa below, however it is the same volume as the MK2s.
Extremely minor but Prusa does have a MK2.5 and MK2.5s printer, which were upgrades to the original MK2s.  These printers have the same build volume (as the MK2 and MK2s) but have an updated extruder assembly and upgraded heatbed; leaving these out is likely warranted.
I'm happy to provide more documentation or explain why there is a variance between the MK3/MK3s and MK2/MK2s/MK2.5/MK2.5s.
F360 machine configuration Prusa MK3F360 machine configuration Prusa MK3
Prusa build volume comparisonPrusa build volume comparison
Prusa referenced page: https://shop.prusa3d.com/en/upgrades/179-original-prusa-i3-mk2s-to-mk25s-upgrade-kit.html#
2 Comments
serge.quiblier
Hello @TurboEngineer
As a quick fix, the user can edit the machine configuration by himself.
Finding the machine configuration
We will fix the machine definition in the software installation.
Thanks for helping us improve the software.
Regards.
Discussion_Ad
