New Field in the CAM Forum
How about a new field that is for Help Videos and Formulas, with pics, that can be used to auto calculate steps of toolpaths.
This way it is a quick one stop instead of trying to search out thru all the threads. ???
5 Comments
al.whatmough
we are trying to reduce the number of categories.  But, can can add "Tags".
I will see if we can add "categories" like we have for ideas.  I am sure we can.
al.whatmough
Status changed to: Accepted
We can't add a category.  But, we can add a tag.  Here is a sample post with the tag added:
http://forums.autodesk.com/t5/hsm-support-forum/tips-and-tricks-tapered-helical-plunge/m-p/6623277
Please start adding tags to any post that should have the "Tips & Tricks Tag" added.
As a bonus, create a reply to you post immediately that we can mark as the solution.
This way, you will get the credit for solution provided 🙂
Your reply should be, "was this tip helpful?"
You can now links to tips and tricks with this link:
http://forums.autodesk.com/t5/tag/Tips%20%26%20Tricks/tg-p/board-id/216
lenny_1962
Al,
 the tag things in not ideal, how about a tab? then it's right in peoples faces to add content????
al.whatmough
lenny_1962
@al.whatmough NICE!
