GRBL 5 axis post processor
It's been a while since I use the post processor grbl, it works perfectly and I've never had any problems, but recently I decided to upgrade my machine with two more axes still using the GRBL controller, I found this version of the controller which supports 4/5/6 axis: https://github.com/fra589/grbl-Mega-5X . I arrived almost immediately to a block, Fusion360 does not have a Post Processor for GRBL 5X, so I tried to write one, but with poor results, so I was wondering, is there anyone who can help me with this Post Processor possibly linking me also a guide on how to write Post Processors?
4 Comments
tsmarks
I have put one together that seems to work with my 6Axis GRBL install.  I used the GRBL build from http://eccentricworkshop.com/ as it has the correct pin assignments for my set up, but it should all be built on the same GRBL core.  The CPS file is attached to the forum post here:  Multi-Axis GRBL
Note, I have only tested 4th axis movements on a physical machine.  I don't have a 5th yet.
Good luck!
eragonpower09
That's great! Thanks a lot @tsmarks , i tried posting a 4 axis toolpath and it worked well but i've encountered a problem, my Gcode Sender doesn't support more than 3 axis but it still can send gcode with more axis. Some suggestion about a better gcode sender with multi axis capability?
tsmarks
I use bCNC.  bCNC does not support 4+ axis, but will blindly send the gcode.  i use the terminal to move the a axis (i.e. g1 a360 F1000 to move the A axis 360 degrees) and have a macro set to zero the axis (g92 a0).   This might not be the most elegant solution, but it works for now.  I need to dig into the bCNC code and add more axis.
tsmarks
The new version of bCNC should now support multi axis.  My fork was just merged back into the main.
