error, Multi-axis flow post processor for okuma mu-400V
Hello. please could somebody help me. we have machining center (okuma mu-400V II), when i post a fusion G code for multi-axis, i got the following error ! rewind of machine is required for simultaneous multi-axis toolpath and has been disabled! I found same help in internet and i solved partially doing changes in the generic post, as when i try to run (machining), appears an error "travel limit over y-axis", it maybe because i could not found "var performRewinds" in the generic post for okuma  or is there another equivalent "var" for okuma only? and i did not any change in the generic post for this "var".  I am attaching pictures like, the internet help page that i used, okuma post code, and my work piece designed by fusion 360 using multi-axis flow. thanksx.pngxx.pngxxx.png
