Centroid 4th Axis Capable Post Processor
We have a 4 axis knee mill (ACCU 2) running M400 control with a Centroid Rotary installed with the axis spinning about the X axis.  The rotary axis is labeled "W".  When I've tried posting the wrapped tool path I get this output(Below).  I really wish I knew enough to fix this myself, but alas, I'm not there yet with post processor jargon.  I know there are loads of folks using various Centroid controls & probably a significant number with rotary's attached.  I'd love to see the Centroid users get that capability.  Also, any suggestions/resources I should look at to get a better handle on this part of the CAM process.
Thanks folks!
~George
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Friday, December 21, 2018 6:05:37 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 42089
Configuration path: C:\Users\INSTRO MACHINE\AppData\Local\Autodesk\Autodesk Fusion 360\5C5QL4XKG353\W.login\M\D20171215108718506\CAMPosts\centroid.cps
Include paths: C:\Users\INSTRO MACHINE\AppData\Local\Autodesk\Autodesk Fusion 360\5C5QL4XKG353\W.login\M\D20171215108718506\CAMPosts
Configuration modification date: Tuesday, November 6, 2018 4:15:03 PM
Output path: C:\Users\INSTRO MACHINE\Documents\Cogswell Projects\Comp Chamfer Test.nc
Checksum of intermediate NC data: 7d830974e29796d653b0c7f3ad2f95b6
Checksum of configuration: a8599aee91b1777c5f0c874c7f67bec1
Vendor url: http://www.centroidcnc.com
Legal: Copyright (C) 2012-2016 by Autodesk, Inc.
Warning: Multiple work offsets used in program.
Generated by: Fusion 360 CAM 2.0.5119
Error: This post configuration has not been customized for 5-axis simultaneous toolpath.
Error at line: 784
Error in operation: '2D Contour1'
Failed while processing onRapid5D() for record 36379.
Error: Failed to execute configuration.
Stop time: Friday, December 21, 2018 6:05:37 PM
Post processing failed.
2 Comments
I am stuck here too...
has anyone made a Centroid post processor that supports simultaneous 4th axis tool paths???
pauldonahue1309
Community Visitor
me 2
