Z axis goes G32 Home between 4th axis indexing
chicoGGR33
chicoGGR33
I recently got my 4th axis installed and the post processor working in fusion 360.  I'd like to change how it wastes a bunch of time going G32 (Z to tool change) between each index position.  Here's a test program and the post I'm using.  Any help would be great!
AdamKunzo
try carefully attached PP.
If this answers your question, please use Accept as Solution.
chicoGGR33
What did you change in the post?
chicoGGR33
The modified post doesn't output any 4th axis moves
AdamKunzo
Sorry, try this.
chicoGGR33
Thanks Adam
I looked at a posted test program and it looks like it will work.  I just haven't tried it on my CNC yet.
chicoGGR33
got a chance to try it.  worked great! the z goes up to the clearance level you set in the heights tab.  Just drag it to a safe distance.
Thanks for your help.
