Why dosent my siemens 840D post write cycle800 0 degrees when posting a program?
Vohnsen
Message 1 of 10
Vohnsen
This means it dosent move B til 0 if its not there already when i start..
How do i make so it automaticly will write a cycle800..
See no B0 or Cycle800 0 degrees around B axis.
; %_N_1001_MPF
; T1009 D=20 CR=0 - ZMIN=-15 - flat end mill
G90 G94
G71
G64
G17
L_FREI
D1
; 2D Pocket4
M9
T1009 D1
M6
S5000 M3
G54
G0 X377.862 Y-259.046
G0 Z15
M8
G0 Z-9
G1 Z-13 F2000
G17
G1 X377.86 Y-259.039 Z-13.174
G1 X377.855 Y-259.017 Z-13.347
G1 X377.846 Y-258.98 Z-13.518
G1 X377.834 Y-258.929 Z-13.684
G1 X377.819 Y-258.864 Z-13.845
G1 X377.801 Y-258.785 Z-14
Replies (9)
Message 2 of 10
Vohnsen
Here is the post i am using for my DMU 125 H
Message 3 of 10
Vohnsen
This is how it looks in my DMU 125 FD post...
; %_N_10011_MPF
; T32 D=80 CR=0 - ZMIN=-72 - face mill
G90 G94
G71
G64
G17
L_FREI
CYCLE800(0,"TC1",0,27,0,0,0,0,0,0,0,0,0,0)
; 2D Contour2
M9
T32 D1
M6
CYCLE832(0.01, 112001)
S5000 M3
G54
CYCLE800(0,"TC1",0,27,0,0,0,0,0,0,0,0,0,-1)
G0 X426 Y138 Z15
M8
G0 Z-0.5
G1 Z-3.5 F3000
G17
G3 X418 Y138 Z-11.5 CR=8
G1 X410
G3 X402 Y130 Z-11.5 CR=8
G1 Y-130
G3 X410 Y-138 Z-11.5 CR=8
G1 X418
G2 X426 Y-138 Z-3.5 CR=8
Message 4 of 10
Laurens-3DTechDraw
Can you upload that post too?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 5 of 10
Vohnsen
Here it is mate!
Message 6 of 10
AchimN
When I use your post I do get this:
; %_N_1001_MPF
N10 ; T1 D=50 CR=0 - ZMIN=-1 - Planfraser
N11 G90 G94
N12 G71
N13 G64
N14 G17
N15 L_FREI
N16 CYCLE800(0,"TC1",0,27,0,0,0,0,0,0,0,0,0,0)
N17 ; Face1
N18 M9
N19 T1 D1
N20 M6
N21 S5000 M3
N22 G54
N23 CYCLE800(0,"TC1",0,27,0,0,0,0,0,0,0,0,0,-1)
N24 G0 X63.5 Y-24.375 Z15
Achim.N
Principal Technology Consultant
Message 7 of 10
Vohnsen
hmm thats weird!
Check out my screen cast..
http://autode.sk/28SL00O
Message 8 of 10
AchimN
In your Screencast you selected a post called "siemens-840d.cps" which is the generic post i guess.
This post does not have the machine config enabled, so you will not see CYCLE800 at the beginning of the program.
You uploaded a post called "siemens-840d-FD.cps", this one has the machine config active so you will get a CYCLE800.
Achim.N
Message 9 of 10
Vohnsen
arhh i forgot to enable that... thats it.. it works..
thanks mate!
Message 10 of 10
AchimN
No problem 🙂
Achim.N
