Use always TCP
Use always TCP
marcoCAGYK
Use always TCP
marcoCAGYK
Hi All,
I have a head/head machine that fails with G43, and I would like to use TCP mode G43.4 even when the tool axis is aligned to the Z axis.
As you can see in the example code below, the first machining uses G43 while the second, where there is a rotation, uses G43.4
I would like to make the first machining also use G43.4
Thank you for your help
O1001
(MACCHINA)
(  FORNITORE AUTODESK)
(  MODEL GENERIC 5-AXIS CB HEAD-HEAD)
(  DESCRIPTION THIS MACHINE HAS YXZCB AXIS ON THE HEAD)
(T2 D=16. CR=0.8 - BULLNOSE END MILL)
(T14 D=6. CR=0. TAPER=120DEG - FORATURA)
N10 G90 G94 G17 G49 G40 G80
N15 G21
N20 G53 G00 Z-100.
N25 G00 B0. C0.
(FORATURA3)
N30 T14 M06
(PUNTA D6)
N35 T2
N40 S1400 M03
N45 G17 G90 G94
N50 G54
N55 G00 B0. C0.
N60 G00 G43 X50. Y-50. Z40. H14
N65 G00 Z30.
N70 G98 G81 X50. Y-50. Z-10. R5. F120.
N75 G80
N80 Z40.
N85 G53 G00 Z-100.
(FORATURA3 5)
N90 G00 B90. C-90.
N95 G49
N100 G00 G43.4 X50. Y-115. Z-50. H14
N105 G00 Y-105.
N110 G01 Y-90. F120.
N115 G00 Y-105.
N120 Y-115.
N125 G53 G00 Z-100.
N130 G49
khleeYY9B5
g43이 어디있나요?
