Announcements
Tool change on Okuma Genos 560
Jacopotonello_
Jacopotonello_
I need to change the writing "T...M06" when the tool change with "G116B1T..." and also add a variable that if the through spndle coolant was used in the operation, before changing the tool it need to run "M202" code.
if anyone can help, thank you very much !
BrandonTBFBF
Try this.
I took our M560 post and changed the tool change macro call to G116B1.
Jacopotonello_
I copied a part of your post  in change to a part of mine and it seems to work! very helpful, Thank you so much for the help !
I put the post down here so u can tell me if it's right  !
thank you !
