Tapping Cycle is outputting wrong code, all operations are posting with tool break detection without the option to remove. Please help!
cjelley91
cjelley91
I recently started editing a post processor for a Mazak with A axis rotary table. Most of the changes I made seem to be ok,  however I am experiencing a few issues.
First, the tapping with chip breaking cycle is outputting the code as follows:
(10-32 STI CUTTING TAP)
M1
G90
T18 M6
T28
S800 M3
G59
A0.
M8
G0 X2.3 Y-1.9
G43 Z1. H18
G0 Z0.1
G98 G95 G84 X2.3 Y-1.9 Z-0.9 R0.1 P0 Q0.2 F0.0312
G73 X2.3 Y-1.9 Z-0.9 R0.1 Q0.2 F25. K0.25 ***** (I NEED THIS LINE OF CODE REMOVED) *****
Y-0.9
Y0.9
Y1.9
X5.03
Y0.9
Y-0.9
Y-1.9
G80 G94
G0 Z1.
M9 *****(This Line and the line below are being added to every tool, I would like the option for tool break detection)*****
M350 *****(This is the M code for tool break detection) I'm not sure why every tool is automatically using this*****
M5
G53 Z0.
M152
M30
My modified post processor is attached below. Thank you.
cjelley91
I like how the post is outputting tool measurement after all cycles, however is there a way to disable this for certain tools within the software? Examples: shell/face mill, chamfer mills etc.?
When running multiple WCS my old post would post G0 Z5.0 to raise the machine to 5 inches above the work surface, now this new post is going to G53 Z0. I would also like this addressed.
I would also like the line at the end of the operation:
G53 Z0. (CHANGED TO G28 G91 Z0.)
THANK YOU!
will_1
Hi @cjelley91 ,
For the G73 issue you need a to add a break between your cases like this...
        break;
    case "chip-breaking":
For the G53 issue you can edit the writeRetract function to give you the output you are wanting.
Will
cjelley91
How would I modify this to move produce a G0 Z5.0 in between new work offsets? Is this what you're talking about?
writeRetract(Z);
zOutput.reset();
setWorkPlane(new Vector(0, 0, 0)); // reset working plane
will_1
Hi @cjelley91 ,
It makes sense to put it in the writeRetract function, but you don't have too. I would look at the newWorkOffset variable to decide when you output the G0 Z5.0.
I am always hesitant to hardcode values like you are wanting in cases where the touch off point is at the bottom of the stock or something like that.
Will
