Setup Sheet
Setup Sheet
Message 1 of 17
Setup Sheet
hi ,
    hi how can I add "Compensation type" parameter in Excel setup sheet as same like as programme parameters are coming in "Operation work sheet"
One Snap is attached.. please have a look...
Replies (16)
Message 2 of 17
shaji wrote:
hi ,
anyone can help to find a solution of this.
Message 3 of 17
makko74
can be thats this helps
normally with
if (hasParameter("operation:compensationType") {
  var compType = getParameter("operation:compensationType");
InfoInventor CAM(Ultimate) user --- Inventor Professional 2021.2 + Inventor CAM Ultimate 8.1.2.21785
Message 4 of 17
normally with
I have tried this .it is not working.. I don't know may be I am doing wrong. Can you send one sample template copy with the compensation parameter.... so it will be easy for us.
Message 5 of 17
makko74
its hard to say where is the error, i dont use a post processor for excel sheet's.
your post processor must be updated, i dont know your post processor.
Message 6 of 17
makko74
my code was only an example to how do get the needed parameter.
is your post processor a generic post, when yes, then can you say me the name of that, then can i have a look
Message 7 of 17
makko74
ok i have found it, sorry normally i dont use excel sheets  😉
you must in the setup-sheet-excel-2007-template.xlsx create a new column (look at the pic)
then in the setup-sheet-excel-2007.cps in onSectionEnd add a line (the last line)
function onSectionEnd() {
  var operationParameters = {};
  operationParameters["id"] = currentSection.getId() + 1;
  operationParameters["description"] = hasParameter("operation-comment") ? getParameter("operation-comment") : "";
  operationParameters["strategy"] = getStrategy();
  operationParameters["workOffset"] = currentSection.workOffset;
  operationParameters["compType"] = hasParameter("operation:compensationType") ? getParameter("operation:compensationType") : "Computer";
Message 8 of 17
Thank you for your replay
Message 9 of 17
hi ,
  I have tried to add the details as per you suggested. But it is not coming.. more Over that I have no idea about this languages...
I am sending a screen shot...in My post process file it is seeing like this.
in this if you suggest anything I can try once again.
Message 10 of 17
makko74
in line 424 you have forget to end the line with an ";" and the solution should be what if, when the condition after the " = " not met (look for example at line 409 )
simplify:
parameter = condition ? what is parameter when condition=true : what is parameter when condition=false;
an simple "if - then - else"
Message 11 of 17
simplify:
  Thank you very Much for your Help....Now It is working..
Message 12 of 17
hi ,
    I am facing an other problem also.. I have a project with 207 tool paths, when I try to create my excel setup sheet.. it is not generating..it is showing error...
But if I select only 125 tool paths it is setup sheet is generating. it I try to add one more tool path it is giving error.
please see the picture of error message
Message 13 of 17
Laurens-3DTechDraw
shaji wrote:
hi ,
It runs out of memory.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 14 of 17
makko74
shaji wrote:
hi ,
Yes Laurens is right, it runs out of memory.
this week i made some tests with this post and had the same error with more than 400 toolpaths.
if you can life without pictures in your setup-sheet then can you try the other generic excel setup sheet post processor, this has not the error.
Message 15 of 17
Laurens-3DTechDraw
makko wrote:
shaji wrote:
hi ,
400 different operations? 😮
What do you guys program?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 16 of 17
makko74
big machine parts laurens  😉
1400x1200mm
five sides machining in one clamping, horizontal/vertical, many threads from M3 to M16 also HeliCoil threads in many sizes. There's a lot coming together
P.S.
oh a little misunderstanding, not 400 operations, over 400 toolpaths and only 256 operations
Message 17 of 17
Laurens-3DTechDraw
1400x1200mm
P.S.
Ah you mean with patterns in them?
But still it feels like more than ever needed. 😛
Laurens Wijnschenk
3DTechDraw
René for Legend.
