Setup sheet to display tools using same tool number with different offsets
jason11
jason11
Can the Setup sheet be edited to display lathe tools that use the same tool number but use different offsets?  For instance on our NLX2500sy, we have tool blocks that hold 4 different tools, and they will all be tool 1 but with offset numbers 1, 21, 41, and 61.  I'd like to be able to print the setup sheet to show all of the tools in one setup sheet and not have to print it multiple times selecting different tools to print.
boopathi.sivakumar
Hi @jason11
Which post processor you are using, we have recently updated the post to show the same tools with different offset numbers.
Boopathi Sivakumar
Senior Technology Consultant
jason11
I'm using setup-sheet.cps
It is the HTML version.  If I download the latest version, I get a error message that i don't have a high enough post engine version to use it.  I've also done slight modifications to the setup sheet post that i have been using to make the text larger in certain areas for my operators.  I've attached the post i am using.
jason11
@boopathi.sivakumar  I'm using the latest setup-sheet.cps html version on InventorCam 2025 and it is still not showing same tools with different compensation offset numbers.
