Setup Sheet output to excel
I've read that you can output a setup sheet to excel format, but I can't figure out how to get it to do it. Everything I've read either says that it can do it, or how to modify the output to something different (layout wise)j
I just want to switch it from outputting the html format to outputting an excel file but can't figure out where.
Using HSM express if that makes a difference...
Thanks!
LibertyMachine
In Fusion 360, the way that one would output to an excel file is through the Post Process dialog, just as if I was going to post out for the machine. In Fusion, the folder for the generic posts also contains 2 excel setup sheet templates AS WELL as two identical named .cps files.
I'd imagine it is a similar setup for HSM
The .cps and excel templates are fully editable
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
