Reverse tool numbering
Why a post processor gives a different order of tools.
It should be the T70 tool first and then T31.
I use fanuc in the Inventor HSM and Fusion 360.
T31.pngT70.pngError.pngLater, I added a new thread creation toolnew tool 01.pngnew tool 02.png
FTKnur
Have you tested it on the machine?
T70 M6 - M6 change the Tool
T31 - just preload in the tool changer
And on the last operation it uses the first tool for preload.
When you don't want preload or it makes complications with your machine just edit the postprocessor:
prelaodTool: true
in
preloadTool: false
then the second T line doesn't exist.
The Tool list begins by 1 - don't know whether the order of the tool list can be changed to the operations order.
It helped, thanks
