have a simple contour going down to the bottom of the stock as a test. When I keep corners sharp gCode is outputted correctly
XL2P X=123.230 Y=151.504 Z=-2.540 V=1829
XL2P X=101.640 Y=151.504 Z=19.050 0 V=1829
XL2P X=20.644 Y=151.504 Z=19.050 0 V=2438
XL2P X=17.469 Y=151.504 Z=19.050 0 V=2438
XL2P X=17.469 Y=234.054 Z=19.050 0 V=2438
XL2P X=163.519 Y=234.054 Z=19.050 0 V=2438
XL2P X=163.519 Y=151.504 Z=19.050 0 V=2438
XL2P X=101.640 Y=151.504 Z=19.050 0 V=2438
XL2P X=101.640 Y=151.504 Z=-6.350 V=0
Note there is no "G0" or "XG0" these are just tracking linear and circular moves
When the corners are changed to "round over" which doesn't change the geometry of the toolpath besides adding arch's in each corner here is the gcode.
XL2P X=101.640 Y=151.504 Z=19.050 V=1829
XL2P X=20.644 Y=151.504 Z=19.050 V=2438
XA2P G=3 X=0000 Y=17.469 Z=-135.629 I=20.644 J=154.679 V=0
XL2P X=17.469 Y=230.879 Z=19.050 V=2438
XA2P G=3 X=0000 Y=20.644 Z=-215.004 I=20.644 J=230.879 V=0
XL2P X=160.344 Y=234.054 Z=19.050 V=2438
XA2P G=3 X=0000 Y=163.519 Z=-211.829 I=160.344 J=230.879 V=0
XL2P X=163.519 Y=154.679 Z=19.050 V=2438
XA2P G=3 X=0000 Y=160.344 Z=-132.454 I=160.344 J=154.679 V=0
XL2P X=101.640 Y=151.504 Z=19.050 V=2438
now everything except the Y is incorrect, and even though the path is all on the same plane the Z is different (Z=-211.829,Z=-132.454,Z=-135.629) it seems to be creating random values. This post was fully working a couple days ago and no changes have been made to it.
function onCircular(clockwise, cx, cy, x, y, z, feed) {
var workpiece = getWorkpiece();
writeBlock(
"XA2P",
"G=" + (clockwise ? 3 : 2),
xOutput.format(x),
yOutput.format(y),
zOutput.format(z-workpiece.upper.z),
iOutput.format(cx),
jOutput.format(cy),
feedOutput.format(feed),
function onLinear(x,y,z,feed) {
if(block != 0) {
writeBlock(
"XL2P",
xOutput.format(x),
yOutput.format(y),
z,
block++;
those are the two functions, completely identical and very simple. the formatting is also identical the onLinear works fine with proper Z circular just spits out whatever. The Z onLinear is also correct and this post was working before so I have ruled out a WCS issue.
I recently paid for fusion on cyber monday because I got this post working a few weeks ago and ran multiple tests crossing multiple projects all working fine with archs and circles. Now it just seems like there is no way out because the output fusion is giving is simply not accurate. Any help would be very appreciated
