Message 1 of 18
Prototrak SLX lathe (XYZ Machine tools)
09:34 AM
I'm trying to get a program to work on my Prototrak SLX lathe.
Over a year ago somebody else on here was trying to do the exact same thing here: https://camforum.autodesk.com/index.php?topic=4934.0
I have made the same progress as they have, manually removing all of the Gcode which generates an error. Specifically G18, G50, G53 and G54. Doing this enables the machine to open the program.
I can look at the tool path and it is fairly obvious that it isn't handling the arcs correctly (it appears the direction, CCW/CW of the arcs comes out the wrong way round). The part will verify with errors around the operations involving arcs and the result is almost the correct part, without arcs (it appears to create chamfers instead).
It would be really great if I could use HSM Pro to run this lathe as I already have two mills which I control with this program (one of which is 20+ years old). It would be a sad shame if my brand-spanking-new lathe could only be programmed manually!
Any suggestions on what I should do next? anyone willing to help?
