Problem enable bAxis and cAxis
cosmedsrl
cosmedsrl
Hi everyone,
I have a 5-axis with Heidenhain system, where the head rotates on the Y axis (bAxis) and the table rotates on the Z axis (cAxis) the machine is not enabled for rotation on the X axis (aAxis), I followed the guide for " disable "aAxis and enable only bAxis and cAxis as reported below:
else if (true) {
    // NOTE: setup your machine here
    //var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120.0001, 120.0001], preference: properties.preferTilt});
    var bAxis = createAxis({coordinate:1, table:true, axis:[0, 1, 0], range:[-5, 90], preference:1});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], cyclic:true});
    machineConfiguration = new MachineConfiguration(bAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(0); // using M128 mode
the problem is that when I go to do the operation where I set the tool orientation (2D Contour ) in the generated file it writes me a "wrong" positioning or better compiles me aAxis and bAxis instead of bAxis and cAxis, as follows :
11 PLANE SPATIAL SPA-90 SPB+90 SPC+0 TURN FMAX SEQ-
if instead he tries to do an operation in "continuous" mode:
this is the result of setting the axes
16 PLANE SPATIAL SPA+0 SPB+27.991 SPC-133.219 STAY
and then afterwards it works "correctly" with bAxis and cAxis, being a 5-axis simultaneous machining
my question is:
as it is possible to set in the PP not with 5 simultaneous axes but a simple Tool Orientation by rotating exclusively bAxis and cAxis.
PP --> https://cam.autodesk.com/posts/download.php?name=heidenhain
the only thing changed is the initial enablement for bAxis and cAxis
KrupalVala
Hi @cosmedsrl ,
It's because of Euler angle.
You can use/change workplane with other methods. To change Tilted workplane go to Post Properties and you will find "usePlane"
Specifies the tilted workplane you can choose below method based on your controller/requirement.
1) none : Use rotary angles
2) true  :  Use Plane Spatial
3) false : Use Cycle19
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
