Postprocessor issue - How to remove G43.4 code
connectmechtech
connectmechtech
I am using MITSHUBISHI GENERIC POST PROCESSOR. While using 4th axis in machine the posted code showing G43.4 code which is not required for 4th axis machining. How we can change the post for 4th axis machining only as the post is enbled for 4th and 5th axis both..
AchimN
There is no need to change the postprocessor for this.
All you need to do is to disable the TCP option in your machine definition as shown in the screenshot below.
Into the "Kinematics" tab you will find your rotary axes. Select the desired axis and disable the "TCP" option.
Then the post will no longer output G43.4.
Achim.N
Principal Technology Consultant
connectmechtech
THANK YOU Achim.N it is working fine now.
